Unsecure ms9s12p128
Unsecure ms9s12p128
MUXU
I have set the backdoor access key for mc9sp128 and configured the security state.
Now I want to read the flash content. How can I unlock it?
MUXU
void Verity_BackdoorKey(void)
while((FSTAT&0X80) == 0){
if(FSEC&0X03)!=0X02 && (FSEC&0XC0) == 0X80) {
FSTAT=0X30;
FCC0BIX=0X00;FCCOB=0X0C00;
FCC0BIX=0X01;FCCOB=0X1234;
FCC0BIX=0X02;FCCOB=0X4567;
FCC0BIX=0X03;FCCOB=0X89AB;
FCC0BIX=0X04;FCCOB=0XCDEF;
Disable_Interrupt();
FlashOperateRun;
Enable_Interrupt();
MUXU
FSTAT=0X30;
FlashOperateRun;
Enable_Interrupt();
danielmartynek
HI @MUXU,
Refer to this document:
https://community.nxp.com/t5/S12-MagniV-Microcontrollers/S12-X-MCU-Security/ta-p/1111118
Once the MCU is unlocked via the backdoor key, you need to attach the debugger without resetting the MCU, any reset would lock the MCU again.
MUXU
First of all,thank you for your help.
I saw that there is a example in AN2880.pdf,but I couldn't find the AN2880SW.zip file.
Could you please assist me with this?
%3CLINGO-SUB%20id%3D%22lingo-sub-2250856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUnsecure%20ms9s12p128%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20set%20the%20backdoor%20access%20key%20for%20mc9sp128%20and%20configured%20the%20security%20state.%3C%2FP%3E%3CP%3ENow%20I%20want%20to%20read%20the%20flash%20content.%20How%20can%20I%20unlock%20it%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2250856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESecurity(Edgelock%20%7C%20secure%20boot%20%7C%20OTP)%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2251741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20Unsecure%20ms9s12p128%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2251741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Evoid%20Verity_BackdoorKey%EF%BC%88void%EF%BC%89%3C%2FP%3E%3CP%3E%EF%BD%9B%3C%2FP%3E%3CP%3Ewhile%EF%BC%88%EF%BC%88FSTAT%26amp%3B0X80)%20%3D%3D%200)%7B%3CBR%20%2F%3Eif(FSEC%26amp%3B0X03)!%3D0X02%20%26amp%3B%26amp%3B%20(FSEC%26amp%3B0XC0)%20%3D%3D%200X80)%20%7B%3C%2FP%3E%3CP%3EFSTAT%3D0X30%3B%3C%2FP%3E%3CP%3EFCC0BIX%3D0X00%3BFCCOB%3D0X0C00%3B%3C%2FP%3E%3CP%3EFCC0BIX%3D0X01%3BFCCOB%3D0X1234%3B%3C%2FP%3E%3CP%3EFCC0BIX%3D0X02%3BFCCOB%3D0X4567%3B%3C%2FP%3E%3CP%3EFCC0BIX%3D0X03%3BFCCOB%3D0X89AB%3B%3C%2FP%3E%3CP%3EFCC0BIX%3D0X04%3BFCCOB%3D0XCDEF%3B%3C%2FP%3E%3CP%3EDisable_Interrupt()%3B%3C%2FP%3E%3CP%3EFlashOperateRun%3B%3C%2FP%3E%3CP%3EEnable_Interrupt()%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2251445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unsecure%20ms9s12p128%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2251445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFirst%20of%20all%2Cthank%20you%20for%20your%20help.%3C%2FP%3E%3CP%3EI%20saw%20that%20there%20is%20a%20example%20in%20AN2880.pdf%2Cbut%20I%20couldn't%20find%20the%20AN2880SW.zip%20file.%3C%2FP%3E%3CP%3ECould%20you%20please%20assist%20me%20with%20this%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unsecure%20ms9s12p128%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199597%22%20target%3D%22_blank%22%3E%40MUXU%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3ERefer%20to%20this%20document%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS12-MagniV-Microcontrollers%2FS12-X-MCU-Security%2Fta-p%2F1111118%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS12-MagniV-Microcontrollers%2FS12-X-MCU-Security%2Fta-p%2F1111118%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EOnce%20the%20MCU%20is%20unlocked%20via%20the%20backdoor%20key%2C%20you%20need%20to%20attach%20the%20debugger%20without%20resetting%20the%20MCU%2C%20any%20reset%20would%20lock%20the%20MCU%20again.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
