Trivia Question - What does the HCS (as in HCS12) stand for?
3,913 次查看
admin
Specialist II
The prefixes HC and HCS have been around for awhile, and someone the other day asked me what it meant and I honestly did not know.  So,  I looked and asked around and I actually can't find the answer.  I have some guesses...but was wondering if anyone knew exactly?
2,300 次查看
mculater
High-speed CMOS is what "HC" stands for (e.g. 74HC573).  The letter "S" was added when the designs migrated to a smaller-scale fabrication process, which resulted in a smaller, speedier product.
Carl Barnes
www.technologicalarts.com
Evaluate * Educate * Embed
2,300 次查看
Lundin
Senior Contributor IV
HC stands for Hot Carrier and it refers to the transistor type in the IC. Some semiconductor guru can explain what that means, I'm a software guy :smileyhappy:
The CPU itself was originally called "Star 12", as opposed to the existing MC68HC12. Luckily, someone decided to abandon that silly name and shorten it to S12. Probably because it sounded too similar to the Starcore DSP?
2,301 次查看
mculater
Carl Barnes
