My problem is similar to:
https://community.nxp.com/t5/S12-MagniV-Microcontrollers/Lin-stack-issue-incorrect-sync-delimiter-le...
But that solution did not helped, I mean my delimiter length is still too short after voltage increase.
The best solution would be to make delimiter longer - for example 2-bits.
Is there any based solution to do that?
I tried with example codes from XGATE - without success.
Thank you for any help.
Piotr
已解决! 转到解答。
Hi Daniel,
Microcontroller is mc9s12zvla128
Stack is the solution from my company.
Now I have found solution that starts timer after break detection. So i created additional delay to achieve this.
Hi Piotr,
Which MCU and Stack version do you use?
Thank you,
BR, Daniel
