Stopping EEPROM from beign Erased when Programing
2,156 次查看
rayhall
Is there some way to stop the data stored in the EEPROM memory from being erased  when you program/debug the S12G128.
I am using the PE-Micro USB Multilink.
Ray.
2,036 次查看
ZhangJennie
hello
please follow attached video to avoid eeprom being erased during download.
please don't forget save configuration after setting.
with video setting, then next time you relaunch debugger, eeprom will not be erased.
Zhang Jun
2,037 次查看
ZhangJennie
hello
Zhang Jun
