Serial bootloader interface for S12Z
2,350件の閲覧回数
adrimen_9
I am trying to program the s12zvl DHRD-S12ZVL-NCX3320 via the Serial bootloader interface but it doesn't work.
Thanks in advance.
3 返答(返信)
2,327件の閲覧回数
danielmartynek
Hello @adrimen_9,
Please make sure you routed the SCI module to the correct RX/TX pins on the board.
You can start with a simple SCI example (attached) and use a logic analyzer to scope the bus, just to test the connection.
BR, Daniel
2,311件の閲覧回数
adrimen_9
How can I flash the software you have given me?
And in what format?
Thanks in advance.
2,304件の閲覧回数
danielmartynek
Hi @adrimen_9,
You need to have CW11.1 IDE for MagniV
Evaluation version can be downloaded here:
https://www.nxp.com/design/software/development-software/codewarrior-development-tools/codewarrior-l...
And a programmer
like PE Micro Multilink FX
https://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320180&productTab=1
BR, Daniel
