Serial Monitor
Serial Monitor
1,420 次查看
Pogo
Hi all,
I've used the Serial Monitor to add/update my firmware to MC9S12C. Now I change my hardware from MC9S12C to MS9S12P,  but Serial Monitor doesn't support this device.
Does anyone modify Serial Monitor for MC9S12P, please share to me. Thanks  a lot.
Pogo
1,060 次查看
jsmcortina
There is only a fairly small amount of CPU derivative specific code within the monitor. Mainly you need to check the defined addresses for the serial port and boot-pin if you use it and the flash page addresses and values.
James
