Schematic S9S12HY64
Schematic S9S12HY64
1,484 次查看
Firecell6000
We're a team of students working on a university project and we would like to use the S9S12HY64 (64 pins package).
The problem being that we can't seem to find any schematic for it. The datasheet only give a PCB layout but no actual schematic with components names/values.
We're looking for a minimalistic schematic as we're only using the CAN module and the IIC module.
Thank you!
1,105 次查看
J2MEJediMaster
Specialist I
The data sheet that you can obtain off of this web page has a block diagram of the part, with links to the pins.
---Tom
1,105 次查看
peter_pinewski
You can actually go to Axiom's website and find the demo cluster's schematic
http://axman.com/?q=node/353
From the Axiom home page, click on "support".  You should see a category HC(S)12.  Then find the 9S12HY demo board (DEMO9S12HY64).  This will have schematics and the user's guide for the demo board.
-petep
