Sample makefile of S12ZVM
1,702 次查看
huuhuynhchi
Dear all,
I would like to manage my source to build into executable file (.s19). I used COSMIC compiler but I haven't had any experience about makefile. If you had a sample makefile to manage a big source code, Could you please help me ? I also wrote a makefile for my example code as the attached file and I would like to assign my executable file (.s19) to a specific folder to easily manage. Example: output includes : *.s19, *z12 and *.map and I hope that can put them in a folder different from source folder.
Thank all very much!
Original Attachment has been moved to: S12zvm.mak.zip
Original Attachment has been moved to: source.zip
标记 (3)
1,381 次查看
RadekS
Hi Huu,
Unfortunately I don't have experiences with COSMIC compiler. However I suppose that there must be some configuration for that.
Did you contacted COSMIC?
http://www.cosmic-software.com/support_form.php
I hope it helps you.
RadekS
