S12ZVMC64/128 Stack Size measurement
hyundam
I measured the stack size by making S12ZVMC64 and S12ZVMC128 respectively as Bareboard projects in Code Warrior.
measuring stack size result is S12ZVMC64 is 258byte and S12ZVMC128 is 258byte.This result seems miscalculated.
how should i measure the stack size?
I think S12ZVMC128 is 1024byte and S12ZVMC64 is 512byte.
