S12XE Four Cylinder Engine Management
1,353件の閲覧回数
rayhall
Contributor V
I am going to develop a engine management ECU based on the S12XE. I have bought the KIT33812ECUEVME Small Engine Control and have studied the code. This has been helpful.
I am looking to another code example that will give me a deeper understanding of how to achieve the best engine control.
  Ray.
3 返答(返信)
1,240件の閲覧回数
iggi
Hi Ray,
i found a project based on S12P device for a scooter which has a two-cylinder engine i suppose.
Not sure if this can be of help to you, but the actual problem i see if we can share this with you at all.
Maybe it would work with some NDA.
iggi
1,240件の閲覧回数
rayhall
Contributor V
Hello Iggi,
Is this the project from the freescale Small Engine Control  KIT33812ECUEVME. If it is, then I have that code as I bought the kit. If not,  then I would be intrested in seeing the code. Maybe email it to me if posible,
Ray.
1,240件の閲覧回数
iggi
The project i found (under different name) is the same as KIT912S812ECUEVM_Project.zip delivered with the kit. I compared the source files and there is no difference.
It looks like there are no other codes/projects related with this kit for studying.
iggi
