Example code pack for S12G contains simple code examples how to initialize and how to use MCU module/feature.
List of examples:
G128-API_wakeup_from_Stop_Mode
G128-Clock and COP examples
G128-Interrupt_catcher-CW51
G128-LIN-CW51
G128-PLL_PEEmode-CW51
G128-Security-CW51
G240-API+STOP-CW51
G240-API-CW51
G240-ATD+GPIO-CW51
G240-ATD-Continuous_conversion_with_interrupt-CW51
G240-ATD-Multichannel_single_conversion-CW51
G240-ATD-Single_conversion-CW51
G240-Checksum-CW51
G240-Flash-CW51
G240-PLL-PBE_mode-CW51
G240-PLL-PEE_mode-CW51
G240-PLL-PEI_mode-CW51
G240-TIM_50us_interval-CW51
G240-TIM_50us_period-CW51
GN32-EEPROM-EW-CW51
GN32-LIN-CW51
GN32-PWM16b_GPIO
GN32-PWM_8bit-CW51
GN32-SCI_SPI_Gateway-CW51
GN32-SCI_wake_up_from_stop-CW51
Oct-22-2013 Update:
I added G128-CAN-CW51, G240-SPI-MC33810-CW51, G240-SPI-Slave examples.
I added PLL calculator.
I fixed error in GN32-EEPROM-EW-CW51 example code.
Aug-21-2015 Update:
Updated G240-Flash-CW51 example code.
Removed image files and object code from projects (9MB->2MB size)
The attached zip file S12G_examples.zip can not be opened. Please attach the correct one. I only need the GN32-EEPROM-EW-CW51 example code. Thank you
Thank you for notification.
S12G Example Pack was reloaded.
RadekS
