Regarding Position control and PID control for S12ZVM controller
1,055 次查看
pratibhasurabhi
Contributor V
Dear NXP team,
 I am using S12ZVMl128 evaluation board with angle sensor TLE5501.
I want to know is there any application SW available having position control and PID control implemented. Specially D control in PID.
Request you to share the  SW code  or any information regarding same.
963 次查看
pachamatej
there is no official NXP position control application example available for MagniV. However, I believe you can find necessary information in Automotive Math and Motor Control Library Set | NXP , where the PI or PID controllers are implemented (GFLIB_ControllerPIDpAW - PID controller in parallel form with Anti-Windup).
I believe you can implement it just by following the example in the documentation. Tuning of the PID controller is however heavily application-specific and I recommend to follow literature on that matter.
I hope it helps,
Matej
