Regarding MTRCKTSBNZVM128 board
2,632 次查看
pratibhasurabhi
Hello,I am using MTRCKTSBNZVM128 evaluation board.I have to generate PWM interrupt configuring the PMF.I tried it but interrupt is not generating.Could you please suggest me how to do this?
2,424 次查看
RadekS
Hi Pratibha,
The PMF block may generate 5 types of interrupt (PMF Reload A, PMF Reload B, PMF Reload C, PMF Fault, PMF Reload Overrun).
For example, the PMF Reload A interrupt may be enabled by PMFENCA_PWMRIEA = 1; command with enabled I-bit maskable interrupts (EnableInterrupts;).
The PMF Reload A ISR may be defined for example as:
Interrupt VectorNumber_Vpmfra void PMF_Reload_A_ISR(void)
PMFFQCA |= PMFFQCA_PWMRFA_MASK; //clear PWMRFA flag
//your code
Please look at our application note AN5190 S12ZVM Derivatives Configuring PMF Module for your inspiration.
http://www.nxp.com/files/microcontrollers/doc/app_note/AN5190.pdf
http://www.nxp.com/files/microcontrollers/doc/app_note/AN5190SW.zip
I hope it helps you.
Radek
2,424 次查看
jgerhardy
Hello Radek,
thanks for the link to the software. I found the AN5190 but searching for AN5190SW give no results until, so I was happy to find this post. It helped me a lot.
Thanks again.
John
