Regarding Cosmic Compiler for Freescale S12G128
2,272 次查看
arjunreddy
Hello Everyone,
For preprocessing iam using gcc, for compiling and linking iam using Cosmic compiler. But after preprocessing, during compilation phase it showing error as"bad # syntax". This is because while preprocessing gcc will add # and line to includes. But this syntax is not accepting in cosmic compiler. Any compiler option or flag is available to suppress this error?
Another thing is cxs12x.exe(compiler for cosmic) is doing process from parser to code generater to compilation. Is any option to use cxs12x only as compiler?
标记 (2)
1,638 次查看
lama
Have yu tried to contact cosmic help line Cosmic Software - Support
(Cosmic Software - Contact Information)
best regards,
Ladislav
1,638 次查看
Wlodek_D_
Senior Contributor II
Thank you for your post, however please consider moving it to the right community place (e.g.CodeWarrior Development Tools or 16-bit Microcontrollers )  to get it visible for active members.
For details please see general advice Where to post a Discussion?
Thank you for using Freescale Community.
