RAM Segment Error Messgage.
ソリューションへジャンプ
2,671件の閲覧回数
rayhall
Contributor V
I am getting this error message..
Link Error : L1102: Out of allocation space in segment RAM at address 0x2466
The help tells me to...
Set the end address of the specified segment to an higher value.
How and where do I do this.
Ray.
2,443件の閲覧回数
kef
Specialist I
Your ecu struct needs almost 10k of RAM. This won't fit nonpaged RAM, which is only 8k. You may extent your nonbanked RAM up to 12k like suggested here
https://community.freescale.com/message/334635#334635
4 返答(返信)
2,443件の閲覧回数
ZhangJennie
Link Error : L1102 means “The specified segment is not big enough to contain all objects from the sections placed in it”. please check the prm file, if you can allocate more RAM memory to the RAM object. if you can't solve the problem, please upload the project here. we will check.
2,442件の閲覧回数
rayhall
Contributor V
Jun,
I have supplied the project in zip file.
Ray.
2,443件の閲覧回数
kef
Specialist I
2,442件の閲覧回数
rayhall
Contributor V
Edward,
Thank you. That worked..
Ray.
