Programming with PROG12Z
morag
Has anyone tried programming an MC9S12NE64 with the P&E USB multilink and PROG12Z? I am having trouble as everything seems to program okay but on trying to verify the module I get errors and the code does not run. I would appreciate any suggestions.
helper
i worked with the equipment you mentioned but different HC12 chip.
in prog12Z you need to load the right algorithm and then load your software (better in PHY format).
to program , you need to "ERASE MODULE" first and then "PROGRAM MODULE"
helper
