Hi, I face the same problem like you,there have no pwm in i/o port.And my code as follow: Can you give me same advice?
void initPMF(void){
PMFCFG0_EDGEA = 1;
PMFCFG0_EDGEB = 1;
PMFCFG0_EDGEC = 1; //01 23 45 complementary pwm pair and edge-aligned pwm
PMFCFG0_INDEPA = 1; //independent mode
PMFCFG0_INDEPB = 1;
PMFCFG0_INDEPC = 1;
PMFCFG2_REV0 = 1; // 01 PWM generator A generates reload event.
PMFCFG2_REV1 = 0;
PMFOUTB = 0x2A; // Low MOSFETs ON while SW control (Unipolar PWM) 01 23 45 complementary pwm pair
PMFCFG3_VLMODE = 0x01; // Writing to value register zero also writes to value registers one to five
//PMFFEN = 0 // Fault disabled
// .... (other fault registers)
PMFFQCA = 0; // Reload every PWM, Half-cycle disabled, f core / 1(25Mhz)
PMFMODA = 1250;
PMFDTMA = 13; //dead time
PMFCFG2 |= 0x3f; // mask all PWM outputs
PMFOUTC_OUTCTL = 0x3f; // all outputs in Software mode
PMFENCA_LDOKA = 1; // apply PMF Modulo value
PMFENCA_RSTRTA = 1; // 1 = PWM restart at commutation event
PMFENCA_PWMENA = 1;
//PMFENCA_PWMRIEA = 1; // Reload Interrupt - Used only for debugging
PMFCFG1_ENCE = 0; // buffered PMFOUTC, PMFOUTB, SWAPx and MSKx (change on commutation event)
PMFENCA_GLDOKA = 1; // 0 = Local LDOKA controls buffered registers / 1 = external Load OK controls buffered registers
MODRR1_PWMPRR =0x01; //PWM router
MODRR1_PWM54RR = 1;
MODRR1_PWM32RR = 1;
MODRR1_PWM10RR = 1;
