First of all, the Excel you have shared is obsolete tool, already replaced by MCAT (FreeMASTER-integrated web-based interface with control page and all the settings).
If the motor speed is wrong even in open loop mode, there are two possible reasons:
- the motor pole-pair number is not correct
- the algorithm timing is wrong, which usually happens when
- CPU clock is set differently from the original software
- ADC-done or PMF-reload interrupt timing is set differently (e.g. number of reload opportunities, PMF modulus, reorganized ADC triggers)
What is the "wrong" speed in relation to the real speed?
Matej
