Max3050 CAN communication with XEP100
1,604 次查看
madhura_bhandig
Hello everyone,
I am working on CAN communication between two XEP100 controllers. I am using MAX3050 CAN IC.
The resistance between CANH and CANL is to be 120 Ohm, but I am getting 167KOhm.
This is causing problem in communication, I am getting a dummy data in Rx side.
Please guide me regarding this.
Thanks in advance
Madhura
1,539 次查看
danielmartynek
I'm not familiar with MAX3050 but I guess you should add an external 120ohm termination.
