Machine cycle of MC9S12XHZ512 micro-controller.
977件の閲覧回数
kdn
How can I calculate machine cycle of MC9S12XHZ512 micro-controller.
I want to create time delay in MC9S12XHZ512 micro-controller using Timer, I have used 16MHz crystal on my micro-controller board with no prescale, Can someone explain me how can I calculate delay of 1ms if I am using 16-bit Timer.
872件の閲覧回数
lama
Here is an example for similar MCU with a lot of description:
* Freescale Semiconductor Inc.
* (c) Copyright 2004-2005 Freescale Semiconductor, Inc.
* ALL RIGHTS RESERVED.
Services performed by FREESCALE in this matter are performed AS IS and without
any warranty. CUSTOMER retains the final decision relative to the total design
and functionality of the end product. FREESCALE neither guarantees nor will be
held liable by CUSTOMER for the success of this project.
FREESCALE DISCLAIMS ALL WARRANTIES, EXPRESSED, IMPLIED OR STATUTORY INCLUDING,
BUT NOT LIMITED TO, IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR
A PARTICULAR PURPOSE ON ANY HARDWARE, SOFTWARE OR ADVISE SUPPLIED TO THE PROJECT
BY FREESCALE, AND OR NAY PRODUCT RESULTING FROM FREESCALE SERVICES. IN NO EVENT
SHALL FREESCALE BE LIABLE FOR INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF
THIS AGREEMENT.
CUSTOMER agrees to hold FREESCALE harmless against any and all claims demands or
actions by anyone on account of any damage, or injury, whether commercial,
contractual, or tortuous, rising directly or indirectly as a result of an advise
or assistance supplied CUSTOMER in connection with product, services or goods
supplied under this Agreement.
* File      main.c
* Owner     r62780
* Version   1.0
* Date      Sep-15-2010
* Classification   General Business Information
* Brief     FLASH E/W
* Detailed Description:
* - the SW software demonstrates one of the possibilities how to generate SW
    delay by means of ECT.
* - Generates only one impulse given length after the delay of given length
* - The hard delay, which means the CPU does not work on another task, is presented.
*   It waits in loop.
* - Theory:
* interval = TCx * dt = TCx * (prescaler/fbus)
* TCx = interval / (prescaller/fbus) = interval * fbus / prescaler
* There are two ways for TCx and prescaler setup:
* 1) prescaler = constant (min and max interval is given)
* 2) prescaler and TCx are considered as a variables to calculate required interval
*    interval = f(TCx, prescaler)
*    this solution is more difficult
* This example solves item 1.
*    - Prescaler = const = 8.
*    - fbus = 8MHz
*        - TCx = interval / (prescaller/fbus) = interval * fbus / prescaler
*         Max interval can be calculated as interval[us]=65535*prescaler/fbus[MHz]
*     and setup precision is dt=prescaler/fbus
*     for fbus = 8MHz
*     If prescaler =   1 then max interval is   8191.8 us; dt =  0.125 us
*     If prescaler =   2 then max interval is  16383,7 us; dt =  0.250 us
*     If prescaler =   4 then max interval is  32767,5 us; dt =  0.500 us
*     If prescaler =   8 then max interval is  65535   us; dt =  1.000 us
*     If prescaler =  16 then max interval is  131070  us; dt =  2.000 us
*     If prescaler =  32 then max interval is  262140  us; dt =  4.000 us
*     If prescaler =  64 then max interval is  524280  us; dt =  8.000 us
*     If prescaler = 128 then max interval is 1048560  us; dt = 16.000 us
* - tested on: HCS12X STARTER KIT
*   - OSCCLK = 16MHz, BUSCLK = 8MHz
*   - Reference to documentation: MC9S12XDP512V2 Rev.2.17
Revision History:
Version  Date         Author  Description of Changes
1.0      Sep-15-2010  R62780  Initial version
#include <hidef.h>              // common defines and macros
#pragma LINK_INFO DERIVATIVE "mc9s12xdp512"
#include "map.h"
* Local function prototypes
static void Delay(UWORD interval);
static void ECT_Init(void);
* Local variables
// NONE
Function Name : ECT_Init
Engineer      : r62780
Date          : Sep/15/2010
Parameters    : NONE
Modifies      : NONE
Returns       : NONE
Notes         : Sets ECT for required functionality
Issues        : NONE
  TSCR2 = 0x03;                        // prescaller = 8
  //--- channel 0 setup ---------------
  TCTL1 = 0x00;                        // timer disconnected form output pin logic
  TIOS  = 0x01;                        // channels 0 is output compare
  TIE_C0I = 0;                         // disable interrupt from channel 0
  TSCR1 = 0xF0;                        // enable timer,stop in wait,stop in freeze, fast flag clear
Function Name : Delay
Engineer      : r62780
Date          : Sep/15/2010
Parameters    : UWORD interval
Modifies      : NONE
Returns       : NONE
Notes         : Performs hard delay
Issues        : NONE
TC0 = TCNT + interval;                // set new value and clear interrupt flag
                                       // TC0 = t + interval * fbus / prescaler;
while(!TFLG1_C0F);
Function Name : main
Engineer      : r62780
Date          : Sep/15/2010
Parameters    : NONE
Modifies      : NONE
Returns       : NONE
Notes         : Demonstrate SW delay
Issues        : NONE
void main(void)
for(;;)
   ECT_Init();
   DDRB=0xFF;                          // an output port to visualize period
   for(;;)
       Delay(10000);                   // true delay is value 500*prescaller/busclk=
                                       // = 10000*8/8MHz = 10000us = 10ms
       PORTB = ~PORTB;
The Answer to the Ultimate Question of Life, the Universe, and Everything is:.......... 42.
(Douglas Adams - The Hitchhiker's Guide to the Galaxy)
873件の閲覧回数
lama
THIS AGREEMENT.
* File      main.c
* Owner     r62780
* Version   1.0
* Date      Sep-15-2010
* Brief     FLASH E/W
*   It waits in loop.
* - Theory:
*    - fbus = 8MHz
*     for fbus = 8MHz
Revision History:
#include "map.h"
* Local variables
// NONE
Engineer      : r62780
Date          : Sep/15/2010
Parameters    : NONE
Modifies      : NONE
Returns       : NONE
Issues        : NONE
Engineer      : r62780
Date          : Sep/15/2010
Modifies      : NONE
Returns       : NONE
Issues        : NONE
while(!TFLG1_C0F);
Engineer      : r62780
Date          : Sep/15/2010
Parameters    : NONE
Modifies      : NONE
Returns       : NONE
Issues        : NONE
void main(void)
for(;;)
   ECT_Init();
   for(;;)
       PORTB = ~PORTB;
