MC9S12XDT512 Multi Channel ADC
ernestsnaith
I wish to sample numerous ADC channels (initially 4) with as little processor work as possible at a fairly low frequency (200Hz). Having read the manual a few times and having successfully read a single channel (continuous mode) I am a little confused as to the procedure for multi channel conversion. Please could someone explain how multi channel conversion is achieved. What is wrap around?
Many Thanks
CW4.6
ernestsnaith
Sorry just found datasheet AN2428, problem solved.
