MC9S12XDP512 Missing PLL Filter Calculator
2,106 次查看
christianpeters
Dear all,
in AN3262  a PLL Filter Calculator is described, but in reality it is for 9S12 an cannot be used for the far faster S12X Family,
Is there an apnote using the PLL Filter with the 9S12X family?
1,865 次查看
kef2
Senior Contributor V
Can't find source URL, I found attached EXE stored in my datasheets folder.
Edward
1,865 次查看
christianpeters
Thank you Edward,
In the calculators window here are the terms “stability factor” and “damping factor”.
As I found no appnote or document for the calculator, may you explain these terms to me?
Kind regards
Christian Peters
Senior Field Application Engineer
EBV GmbH & Co. KG
Im Technologiepark 2-8
85586 Poing
Tel. +49 8121 774 533
Fx. +49 8121 774 540
1,865 次查看
kef2
Stability =50 and damping factor =0.9, I think are things, mentioned XDP512 RM
A.5.3.1 XFC Component Selection
The loop bandwidth fC should be chosen to fulfill the Gardner’s stability criteria by at least a factor of 10, typical values are 50. z = 0.9 ensures a good transient response.
I used default 50 and 0.9 for years without any problems. If I had problems with stability or too slow PLL locking, I would study it deeper/
