Is it possible to realize Capacitive Touch solution?
2,443件の閲覧回数
sw_eric_kim
Is S12ZVL possible to realize Capacitive Touch solution?
please let me know if yes...
thanks
3 返答(返信)
2,210件の閲覧回数
danielmartynek
I’m not aware of any software solution directly for S12ZVL.
Touch-Sensing Software Suite supports HCS08, Kinetis and ColdFire.
But you can build hardware solution using sensors.
2,210件の閲覧回数
sw_eric_kim
I understood you mentioned,
but I meaned that is it possible to implement Capacitive Touch without H/W Touch sensor?
that means S12ZVL standalone without H/W Touch sensor IC..?
thank you,
eric
2,210件の閲覧回数
danielmartynek
You may refer to this Application note: Touch Sensing Using GPIO Method.
Although it is for Kinetis, the principles apply for S12Z as well.
You need only a pull-up, electrode and a timer.
