Inquiry of CW development studi0 11.1 connection issue
649 次查看
eric2lim
I've set up Codewarrior Development Studio 11.1 and then connected MultiLink Universal FX to my S12ZVL MCU board.
First of all, my project is passed clean and build process well.
By the way, when I tried to change to debug mode, error popup window displayed..
I attached related log files.
I hope this environment issue will be solved soon.
Best regards.
eric Lim (limbcho_2@hotmail.com)
589 次查看
stanish
thanks for your report.
Could you possibly try to create a new project using " New Project Wizard"?
Please try to build and debug the "Empty" project -> This will help to distingusih if there is a project related corruption or rather the installer is missing some component or is corrupted.
If the new project does not work neither I'd suggest you to re-download and re-install CW for MCU v 11.1 as a administrator on your machine.
Hope it helps.
Stan
