IIC Levels for S912ZVLA
ソリューションへジャンプ
3,754件の閲覧回数
Boris_Bloxsberg
does some know the input levels for the IIC input of the S912ZVLA.
I didn´t find this in the manual.
3,731件の閲覧回数
lama
The IIC input voltage levels for the S912ZVLA microcontroller are not explicitly listed but they are typically defined by the digital input thresholds for the I/O pins used for SDA and SCL.
Typical IIC Pin Thresholds:
For 5V-tolerant I/O (which is common in the S12Z family), the input high voltage (VIH) is typically
0.65 × VDDx and the input low voltage (VIL) is 0.35 * VDDx.
If VDDx = 5V, then guarenteed value:
  • VIH>= 3.25V (minimum to be recognized as HIGH)
  • VIL <= 1.75V (maximum to be recognized as LOW)
Of course, real threshold value is somewhere between (1.75 + 125 mV) and ( 3.25 - 125 mV) considering 250mV hysteresis connected to this threshold for changes between log.0 and log.1
For example
Ladislav
4 返答(返信)
3,377件の閲覧回数
barkerxavierr
Yeah, those VIH/VIL numbers for the S12Z family are pretty standard, especially for 5V-tolerant I/O. Just remember that hysteresis helps a lot with noise, but you really want to  Drift Boss make sure your I2C signals are clean and the pull-ups are strong enough, or you’ll chase ghost errors for hours.
3,356件の閲覧回数
lama
The only issue I see in the internal pull up. They are really weak 20kohm-50kohm. I suggest to use external ones 1k~10k.
Always use external pull-up resistors (typically 4.7kΩ is a good starting point).
You can leave internal pull-ups disabled, or enable them as a backup — but don’t rely on them for I²C operation.
Ladislav
3,732件の閲覧回数
lama
For example
Ladislav
3,725件の閲覧回数
Boris_Bloxsberg
thx
%3CLINGO-SUB%20id%3D%22lingo-sub-2140194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES912ZVLA%E3%81%AEIIC%E3%83%AC%E3%83%99%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ES912ZVLA%20%E3%81%AE%20IIC%20%E5%85%A5%E5%8A%9B%E3%81%AE%E5%85%A5%E5%8A%9B%E3%83%AC%E3%83%99%E3%83%AB%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E3%81%93%E3%82%8C%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157443%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IIC%20Levels%20for%20S912ZVLA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157443%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E5%94%AF%E4%B8%80%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E5%86%85%E9%83%A8%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%AB%E5%BC%B1%E3%81%84%E3%81%A7%E3%81%99%2020kohm-50kohm%E3%80%821k%EF%BD%9E10k%E3%81%AE%E5%A4%96%E9%83%A8%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%B8%E3%81%AB%E5%A4%96%E9%83%A8%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E6%8A%B5%E6%8A%97%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%20(%E9%80%9A%E5%B8%B8%E3%80%814.7k%CE%A9%20%E3%81%8C%E9%81%A9%E5%88%87%E3%81%AA%E9%96%8B%E5%A7%8B%E7%82%B9%E3%81%A7%E3%81%99)%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%86%85%E9%83%A8%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%83%90%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%A8%E3%81%97%E3%81%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81I%C2%B2C%20%E6%93%8D%E4%BD%9C%E3%81%A7%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%A9%E3%83%87%E3%82%A3%E3%82%B9%E3%83%A9%E3%83%95%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IIC%20Levels%20for%20S912ZVLA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81S12Z%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%20VIH%2FVIL%20%E6%95%B0%E5%80%A4%E3%81%AF%E3%80%81%E7%89%B9%E3%81%AB%205V%20%E8%A8%B1%E5%AE%B9%20I%2FO%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%8B%E3%81%AA%E3%82%8A%E6%A8%99%E6%BA%96%E7%9A%84%E3%81%A7%E3%81%99%E3%80%82%E3%83%92%E3%82%B9%E3%83%86%E3%83%AA%E3%82%B7%E3%82%B9%E3%81%AF%E3%83%8E%E3%82%A4%E3%82%BA%E5%AF%BE%E7%AD%96%E3%81%AB%E5%A4%A7%E3%81%84%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CEM%3E%E6%9C%AC%E5%BD%93%E3%81%AB%3C%2FEM%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fdriftboss3d.io%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EDrift%20Boss%3C%2FA%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81I2C%20%E4%BF%A1%E5%8F%B7%E3%81%8C%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A8%E3%80%81%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E5%8D%81%E5%88%86%E3%81%AB%E5%BC%B7%E5%8A%9B%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E3%82%B4%E3%83%BC%E3%82%B9%E3%83%88%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E4%BD%95%E6%99%82%E9%96%93%E3%82%82%E8%BF%BD%E8%B7%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IIC%20Levels%20for%20S912ZVLA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3ES912ZVLA%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%20IIC%20%E5%85%A5%E5%8A%9B%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AF%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E3%83%AA%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AF%20SDA%20%E3%81%8A%E3%82%88%E3%81%B3%20SCL%20%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%20I%2FO%20%E3%83%94%E3%83%B3%E3%81%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%A8%99%E6%BA%96%E7%9A%84%E3%81%AAIIC%E3%83%94%E3%83%B3%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%3A%3C%2FP%3E%0A%3CP%3E5V%E3%83%88%E3%83%AC%E3%83%A9%E3%83%B3%E3%83%88I%2FO%EF%BC%88S12Z%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%A7%E4%B8%80%E8%88%AC%E7%9A%84%EF%BC%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%85%A5%E5%8A%9B%E9%AB%98%E9%9B%BB%E5%9C%A7%EF%BC%88VIH%EF%BC%89%E3%81%AF%E9%80%9A%E5%B8%B8%3C%2FP%3E%0A%3CP%3E0.65%20%C3%97%20VDDx%20%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%85%A5%E5%8A%9B%E4%BD%8E%E9%9B%BB%E5%9C%A7%20(VIL)%20%E3%81%AF%200.35%20*%20VDDx%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EVDDx%20%3D%205V%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%BF%9D%E8%A8%BC%E5%80%A4%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EVIH%26gt%3B%3D%203.25V%EF%BC%88HIGH%E3%81%A8%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%82%8B%E6%9C%80%E5%B0%8F%E5%80%A4%EF%BC%89%3C%2FLI%3E%0A%3CLI%3EVIL%20%26lt%3B%3D%201.75V%20(LOW%E3%81%A8%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%82%8B%E6%9C%80%E5%A4%A7%E5%80%A4)%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E9%96%BE%E5%80%A4%E3%81%AF%E3%80%81log.0%E3%81%A8log.1%E3%81%AE%E9%96%93%E3%81%AE%E5%A4%89%E5%8C%96%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%81%93%E3%81%AE%E9%96%BE%E5%80%A4%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F250mV%E3%81%AE%E3%83%92%E3%82%B9%E3%83%86%E3%83%AA%E3%82%B7%E3%82%B9%E3%82%92%E8%80%83%E6%85%AE%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81(1.75%20%2B%20125%20mV)%E3%81%A8(3.25%20-%20125%20mV)%E3%81%AE%E9%96%93%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lama_0-1753426926938.jpeg%22%20style%3D%22width%3A%20660px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lama_0-1753426926938.jpeg%22%20style%3D%22width%3A%20660px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349468iF06DDF56DD3C0720%2Fimage-dimensions%2F660x495%3Fv%3Dv2%22%20width%3D%22660%22%20height%3D%22495%22%20role%3D%22button%22%20title%3D%22lama_0-1753426926938.jpeg%22%20alt%3D%22lama_0-1753426926938.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%A9%E3%83%87%E3%82%A3%E3%82%B9%E3%83%A9%E3%83%95%3C%2FP%3E%3C%2FLINGO-BODY%3E
