How to set compiler(Code Warrior)calculate and save CRC checksum at flash
690件の閲覧回数
Gildarai
Hello
I use Code Warrior Compiler 11.1 with S12Z.
I want to calculate checksum of my project and save it at the flash.
And then I want to check it when SW is start up for check whether the SW is correct or not.
For this I think the calculating should performed when compile my project.
So what can I do for this, how can I set the compiler option or pre-do.
タグ(3)
671件の閲覧回数
lama
Have you read.....
 or....
 or....
Ladislav
