How do I understand this mapping in S9S12G
2,047 次查看
jingfang
How do I understand this mapping?
Flash Space page 0xc?
2,025 次查看
lama
Flash memory is programmable using the global addressing space. But, the code runs using the logical address PPAGE_Offset where the offset is from the interval [8000~BFFF]. PPAGE is from the interval [xx~0F], where xx depends on the size of the implemented memory. In the attachment you will find the entire image of the internal memory, I think in a better form. I also attached an example code so that you can see how you can programmatically write and read flash.
In the code you will find ho logical address is converted to global address if you want to use it for programming specific space.
Ladislav
