How can i Disable Interrupts from the debugger?
2,653 次查看
pirate
Message Edited by pirate on 2008-06-05 09:08 PM
1,663 次查看
pirate
I am using MC9s12C64 and the Code warrior version is 5.7.0. I am want to disable interrupts once i stop at a breakpoint and step through code.
Thanks!!
1,663 次查看
allawtterb
Thanks!!
If you are using the P&E Multilink or Cyclone Pro, in the hi-wave debugger it should be under:
MultilinkCyclonePro -> Communication -> Special Setup (tab) -> Disable Maskable ISR's when stepping
