1,307 次查看
Sumit88
1,136 次查看
lama
I have created an example project (see attach) and tested it on the board.
You should check jumper setup on the board (described in the module main.c).
The solution is in polling mode.
The project is created under CodeWarrior 5.1.
Best regards, Ladislav.
