Example project for s912zvhy64
1,699 次查看
yunuskaramavus
I will use s912zvhy64 for an rpm gauge application. Is there any example project  (at least a LED blink) that works on CodeWarrior Development Studio?
Thank you very much.
标记 (1)
1,356 次查看
danielmartynek
We don’t have any simple lab examples ported on S12ZVHY64.
However, you may use the examples from the packages below or any S12Z example here on the community because the peripherals are the same or nearly the same on MagniV MCUs.
TRK-S12ZVH128_DEMOCODE_LABS.zip
S12ZVL-EXAMPLE-CODES.zip
DEVKIT-S12ZVL-LAB.zip
S12ZVC-GETTING-STARTED-EXERCISES.zip
DEVKIT-S12ZVC-LAB.zip
