Error with the MC9S12XDG128MAL
lukegu
Hi Dear ,
       My customer uses the MC9S12XDG128MAL ,  One works well ,but the other doesn't work . Would you kindly help me to check with the attached files ? For One_Right.jpg , the MCU is normal , but for One_Err.jpg , it does not work . The test condition , for both the same PCB and the same peripheral . Thanks a lot !
RadekS
Hi Luke,
I supposed that you want to check tractability/date code.
Unfortunately your request is out of our scope – Checking tractability code is not a technical question.
Please contact your supplier (your Sales Representative or Distributor) with your request.
However I am afraid that your pictures clearly explain why one of MCUs doesn’t work.
And I am shame that I didn’t found it early and spend such time with this request.
If you look at One_Err.jpg, you could see that crystal Y401 is not assembled.
Please assembly crystal.
I hope it helps you.
RadekS
