DSP Dev board Advice
2,436 次查看
brokensaint
Greatings,
I am loking for any sudgestions on a DSP development board and/or Mcu, I want to start doing some audio procesing (filters, audio effects, etc).
Can any one please advice on an adecuate dev board or processor for this aplication.
Thank you.
1,349 次查看
rocco
Senior Contributor II
Hi, Broken:
I use the DSP563xx family of DSPs. Specifically, I use the DSP56303 and DSP56309.
They are designed for audio. They have a 24-bit wide architecture, and interface directly with 24-bit audio codecs. They are also much faster than the Freescale DSC chips (56Fxxxx series). There are versions with surround, THX, Dolby and other audio firmware built in.
I can't help you with development boards however, as the board that I started with has been discontinued. Sorry.
I just tried to get a link for you, but the search function seems to be broken. :smileysad: A search for "DSP563" or "DSP563xx" is giving me invisible results or incomplete results.
1,350 次查看
rocco
Hi, Broken:
1,349 次查看
brokensaint
Thank you for the info Rocco
it has been very helpfull.
