DEMO9S12XDT512 CAN DRIVER
2,095 次查看
candriver
DEAR FRNDS i m using DEMO9S12XDT512 EVB....IN WHICH MC9S12XDT512 WITH XGATE COPROCESSOR S IN BUILT. can i use same "CAN DRIVER"WHICH IS GIVEN IN AN2726.PDF......MEANS WHAT SHOULD I CAHNGE IN CAN DRIVER SOFTWARE FOR MC9S12XDT512... PLEASE HELP ME.........
1,122 次查看
Alban
Senior Contributor II
Hello !
The AN2726 is written for the S12XDT512. You don't need to change the code.
You need to follow the guide to create the mailboxes you need.
Everything is explained is a lot in details in the AN2726.
The software is available with AN2726SW.
Alban.
AN2726SW Source files for AN2726 in ZIP format  FREESCALE  zip  155KB  Rev1  Released Date 3/23/2005
