Codewarrior Illegal initialization of aggregate type
5,964 次查看
rayhall
Contributor V
I keep getting this error when I compile and cannot see why.
The LockupMap[2]12[] array initialization in the C file causes this error and I cannot see anything wrong.
I have included the two files.
Ray.
8 回复数
5,921 次查看
rayhall
Contributor V
This is all I can find that gives a version.
CodeWarrior Development Studio fort he S12(X) Version 5.2, build 151127
Ray.
5,907 次查看
dianabatrlova
Thank you.
One value is missing in the "Real Time Data" in the Cal.c file.
Also, the array below is filled with 25 numbers, but your size is uint16_t lockupMap[2][12]; in the Cal.h
{1,10,20,30,40,50,60,70,80,90,100,110,120,
200,300,400,500,600,700,800,900,1000,1100,1200,1300}, // LockupMap
I believe it helps.
Diana
5,921 次查看
rayhall
Contributor V
5,933 次查看
rayhall
Contributor V
CodeWarrior Development Studio for the S12(X) Version 5.2, build 151127
5,934 次查看
rayhall
Contributor V
5,947 次查看
rayhall
Contributor V
I have version 5.9.0 build 5294
5,948 次查看
rayhall
Contributor V
Ray.
5,952 次查看
dianabatrlova
Can you, please, share the version of CodeWarrior?
Thank you.
Diana
