Codewarrior 4.7 Now Available
2,445 次查看
JimDon
Senior Contributor III
Finally, it is here.
I am downloading it now, but since update has been broken for quite some time, you may not have noticed this.
The 32 file limit is supposed to be removed, and it should install on Vista.
I don't use Vista, so could someone out  there give it a shot?
I will update you after I try it out.
670 次查看
JimDon
Ok, the 32 file limit is GONE!!!
Now lets see if someone can install it on Vista.
