CodeWarrior displays strange warnings? MC9S12X
1,595 次查看
CIA_MAN275
Hello!
Warning:
Link Error: L1822 : Symbol_FSFLOAT in file .... main.c is undefined
..... more Link Errors!!!
What is wrong with my program? Can you pls help me!
THX!
1,327 次查看
kef
Specialist I
In project wizard you specified that you don't want floating point numbers. _FSFLOAT is runtime routine to convert long integer to float.
You should either recreate project and specify that you want floating point. Or check <CW install folder>\lib\hc12c\readme.txt to find what *.lib library file you should add to your project.
1,328 次查看
kef
Specialist I
1,327 次查看
CIA_MAN275
Can you pls explain me the solution with the readme-file more exactly? Sorry for this bad english :smileywink:
And I have also added as a screenshot the other errors!
THX!
