CRC16
CRC16
1,321 次查看
Didier91
Help !
Is there a charitable soul here to give me a routine in assembler (MC9S12...)
for calculating a CRC16??
I have been looking for several days without success.
Thank you and i hope to read you soon.
Didier91
1,283 次查看
lama
We are not able to provide you a code in asm. There is nothing available in our dept. as well as possible contacts.
However, I have collected all possible examples in c or automatic calculation set in the prm file, You can go through them and probably they will help you, If there is a C code example then you can disassemble the project in the CodeWarrior IDE and use it as help to solve your task.
Moreover, they are prepared for older version of MCUs - S12 family and you need to use assembler of MagniV devices.
I am really sorry but direct help is nether possible nor available.
Ladislav
