CAN BUS sample code for S12G96  MCUs.
2,052 次查看
hsuchih-wei
would you please provide me an example S12G96 software drive of can bus
1,489 次查看
ZhangJennie
Hi SHU,
I found some very simple CAN example code directly for S12G:
There is AN4455, MC9S12G128 Demonstration Lab Training. Inside the zip file, you can find CAN_Demo project.
Check the links below.
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4455.pdf
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4455SW.zip
Moreover, very helpful application note could be AN3034 Using MSCAN on the HCS12 family. It could be used as a reference.
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN3034.pdf
Note: this application note was created for older S12 MCUs with msCANv2. S12G have msCANv3, but there are minimum differences.
Hope this helps!
this answer is for you, if it helps, please click on "Correct Answer" button. thanks!
Zhang Jun
1,490 次查看
ZhangJennie
Hi SHU,
Hope this helps!
Zhang Jun
