ATD problem in S12XDP512
2,094件の閲覧回数
FATTY
Currently I'm using a start kit from softec to implement a base environment for motor control, but I encountered some problem when I deal with ATD module. follow is my initial code for ATD module:
ATD1CTL3 = 0x38;
ATD1CTL4 = 0x80;
ATD1CTL0 = 0x05;
ATD1CTL2 = 0x80;
ATD1CTL5 = 0x32;
but in this code, I can't get any data from AD0~AD7, I can only get data from AD8~AD15.
the relation is as follow:
data--->PAD08--->ATD1DR0
data--->PAD09--->ATD1DR1
but data--->PAD00---> can't found in any register....
So it's really bother me a lot. Could somebody also have encountered this problem before? could you give me some hint about this? Thanks a lot in advance.
Fatty
1,291件の閲覧回数
wolbar
I'd love to answer your question however if you can't take the time to comment yuour code...
1,291件の閲覧回数
kef
Specialist I
PAD00 belongs to ATD0...
PAD00..PAD07 - 8 channels of ATD0
PAD08..PAD23 - 16 channels of ATD1
Pin numbering is little odd.
BTW
PT1AD0 stands for port1 of ATD0. And there's no PT0AD0.
PT0AD1 - port0 of ATD1 (PAD16..PAD23 pins)
PT1AD1 - port1 of ATD1 (PAD08..PAD15)
Hope it answer your questions.
