Rapid IoT Connection Platform
2,263件の閲覧回数
zhangxian_ong
Hi there,
For the Rapid IOT, can provide sample and documentation of connecting to several IOT Platform like atmosphere, Pelion and IBM Watson?
2,124件の閲覧回数
stephanie_m
Sorry for the inconveniences this might cause you we do not have an exact example to what you are looking for.
For the Atmosphere information, you can check the following link, there you will find all the documentation available about the Atmosphere environment.
The closest example we have it's the Weather Station one, it is already in the Rapid IoT studio IDE online for you to use, it uses the Amazon Web Services not IBM Watson.
There was a contest some months back, and there were some contestants that enabled IBM Watson, you can verify it is possible to enable it but we do not have that example
Estephania
