NXP Rapid IoT integration with Home Assistant
1,943件の閲覧回数
vlasov01
Home Assistant (hass.io) is popular home automation controller. It already has an entity defined for Air Quality, which can be mapped to NXP Rapid IoT sensors .
I'm wondering if someone already created such integration between NXP Rapid IoT device and Home Assistant?
タグ(1)
1,814件の閲覧回数
Alexis_A
Hi Sergey,
As far as I know there isn't such intergration yet but for the functionality you're asking the Rapid IoT has an example that use a sensor for Air Quality.
In the following link you can find the examples for the Rapid IoT: https://rapid-iot-studio.nxp.com
Check the Rapid IoT Weather Station.
I hope this helps you.
Alexis Andalon
