Is there a new user's guide for MCUXpresso?
3,625 次查看
mrharmonsr
'm trying to get started with the RapidIOT board after putting it aside for a year. Is there a new user's guide for MCUXpresso? I can't figure out how to install the SDK I downloaded from NXP RapidIOT Tools & Software page. Should I simply use the Hexiware stuff?
3,612 次查看
kerryzhou
Hi mrharmonsr,
  All the rapid iot related document is list in the nxp website:
https://www.nxp.com/design/designs/nxp-rapid-iot-prototyping-kit:IOT-PROTOTYPING
  You mentioned the SDK, do you mean the SLN-RPK-NODE-SDK.zip which is downloaded from this link:
https://www.nxp.com/webapp/Download?colCode=SLN-RPK-NODE-SDK&appType=license
If yes, you can find in the folder:SLN-RPK-NODE-SDK\SDK_2.3.0_RapidIoT_MK64F12\docs
 Getting Started with MCUXpresso SDK.pdf
 It can support the mcuxpresso IDE!
You need to drag the code package to the install SDK of the MCUXPresso, just like tomchr mentioned.
From the code package get start document, just K64 has the MCUXPresso IDE project, KW41 rapid don't have the mcuxpresso project.
Wish it helps you!
If you still have questions about it, please kindly let me know!
Kerry
3,613 次查看
kerryzhou
Hi mrharmonsr,
Wish it helps you!
Kerry
3,621 次查看
tomchr
Have you looked in the "Install SDK" section of MCUXpresso? If you can find the SDK there, I would follow that workflow rather than downloading and installing manually.
Tom
