How to observe output to shell in Rapid-IoT
2,212 次查看
wenchen-b37495
I was debugging Rapid-IoT in MCUExpresso and was trying to use shell_write/shell_printf to output some messages.
However I didn't see the shell output in the console of MCUExpresso. How can I observe the output to the shell?  Do I need to use putty to monitor the COM port or something?
标记 (1)
2,054 次查看
estephania_mart
Have you checked the Debug Print Element in the Atmosphere projects  ?
I believe that it's what you are looking for.
Estephania
2,054 次查看
wenchen-b37495
By "Atmosphere projects", do you mean the ones on https://rapid-iot-studio.nxp.com ? I did check that and tried to import it to MCUExpresso. But I didn't find the documentation about it...
2,054 次查看
estephania_mart
There is a manual in the rapid iot page but there is no specific documentations of each example, sorry for the inconveniences this might cause you.
Still, when you download the SDK of the rapid iot there is a hello world example. Have your tried it ?
Estephania
