mechanism for cores' synchronization using interrupts?
walter95
Hi, I'm new in the use of the platform nxp t1040 and I'm looking for a mechanism for cores' synchronization, i.e if it is possible to synchronize cores using interrupt inter-core. A core is in busy wait on a memory location in cache and it waits for an interrupt whose interrupt routine will unlock the core by changing the value of the location mentioned before.
ufedor
Described mechanism looks viable.
walter95
I was thinking of using the 'wait' instruction described in the reference manual, but I don't know how to integrate this instruction in the C code I'm going to write.
@ufedor
ufedor
The 'wait' is an assembler instruction, so you will need to determine a way of insertion assembler into C-code.
walter95
Yeah, sure. I know how to integrate the assembler in the C code. My doubt is how to use well the instruction, i.e what to write in place of WH and WC operands in the manual.
@ufedor
ufedor
Please refer to the e5500 Core Reference Manual
