fmc_pcd
fmc_pcd
arcady_chernyak
example of fmc_pcd-hr.xml or fmc_pcd.xml files
bpe
This post is too short to give an accurate answer, sorry. The file names mentioned in the
Subject field don't seem to appear in any NXP document. However, all available FMC configuration
and policy files can be found in two SDK packages:
eth-config
and
usdpaa-apps
