flash routines
flash routines
2,582 次查看
ramadasr
I am working on BSP for P2041 processor, where can I find eLBC configuration routines( for all the machines)  and also low level write erase routines for NOR and NAND flash? Thanks,
Ramadas
标记 (3)
2,387 次查看
marius_grigoras
Hi Ramadas,
Check this out -> include\configs\P2041RDB.h from u-boot source files.
Marius
2,387 次查看
sinanakman
Senior Contributor III
Hi Ramadas, for NOR flash please refer to the CFI interface and erase command in your flash data sheet. For NAND flash you will find this information in P2041 Reference Manual in the section that describes the flash controller. Hope this helps
Sinan Akman
2,387 次查看
Wei
Have you checked the u-boot source code?
