dsp boot source code B4860
5,749 次查看
Marklyu
i use the QorIQ-SDK-1_7-IC-RevA,
i see the chapter 8 linux user space  IPC, there is dsp_boot (source code of dsp boot loader)part. want to know where can i get/download the source code of it ? the dsp_boot source code is included in the sdk which folder ?
Mark
5,717 次查看
yipingwang
In your Yocto build environment, please run the following command.
$ bitbake ipc-ust -c patch -f
You will get dsp_boot source code in folder.
build_b4860qds/tmp/work/ppce6500-fsl-linux/ipc-ust/git-r0/git/dsp_boot/
9 回复数
5,718 次查看
yipingwang
5,664 次查看
Marklyu
i follow your advice , and the log as below. then there is no source code folder.
build_b4860qds-64b_release]$ bitbake ipc-ust -c patch -f
WARNING: Host distribution "CentOS-7.2.1511" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |######################################| ETA: 00:00:00
Loaded 3921 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.22.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "CentOS-7.2.1511"
TARGET_SYS = "powerpc64-fsl-linux"
MACHINE = "b4860qds-64b"
DISTRO = "fsl-networking"
DISTRO_VERSION = "1.6"
TUNE_FEATURES = "m64 fpu-hard e6500 altivec"
TARGET_FPU = "hard"
meta
meta-yocto
meta-yocto-bsp = "(detachedfromfsl-sdk-v1.6):0d2ce44c2b0f8cc9699e30cca2c24655be89d58b"
meta-fsl-ppc = "(detachedfromfsl-sdk-v1.6):6cf59d9de63a9fc5f8942c0d10c622898f4315ce"
meta-fsl-ppc-toolchain = "(detachedfromfsl-sdk-v1.6):a546e42f86e7d57de19e27907365d170b13fc18f"
meta-fsl-networking
meta-fsl-networking = "(detachedfrom8dec9c6):8dec9c690188cce5305ef5055f91e5cfa35c63f4"
meta-virtualization
meta-virtualization = "(detachedfromfsl-sdk-v1.6):8044073f63a0d99541a43ac5f2f6d789f94c7c7c"
meta-oe
meta-networking
meta-webserver
meta-ruby
meta-filesystems = "(detachedfromfsl-sdk-v1.6):b86007f742a1b829ccc8d76e485bb3f789cefaa4"
meta-java = "(detachedfromfsl-sdk-v1.6):d01f7d39e513790ddce20e6724723722119a3700"
meta-openstack
meta-openstack-compute-deploy
meta-openstack-controller-deploy
meta-openstack-qemu = "(detachedfromfsl-sdk-v1.6):f627404399a134672e0b5e26a0d9b794a6f8adf4"
NOTE: Preparing runqueue
NOTE: Tainting hash to force rebuild of task /sdb/marklyu/QorIQ-SDK-V1.6-20140619-yocto/meta-fsl-ppc/recipes-bsp/ipc/ipc-ust_git.bb, do_patch
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: Tasks Summary: Attempted 10 tasks of which 9 didn't need to be rerun and all succeeded.
Summary: There was 1 WARNING message shown.
5,661 次查看
yipingwang
Please check whether build_b4860qds/tmp/work/ppce6500-fsl-linux/ipc-ust exists.
5,656 次查看
yipingwang
Please go to folder build_b4860qds/tmp/work/ and run the following command.
find . -name ipc-ust
5,636 次查看
Marklyu
thanks much . found the source code files at ppc64e6500-fsl-linux/ipc-ust/git-r0/git.
5,634 次查看
yipingwang
OK, thanks.
5,658 次查看
Marklyu
no, there is no ipc-ust folder under the  ppce6500-fsl-linux.
ppce6500-fsl-linux]$ ls
lib32-binutils lib32-gettext lib32-ncurses
lib32-binutils-cross lib32-gmp lib32-openssl
lib32-bison lib32-inputproto lib32-opkg-utils
lib32-bzip2 lib32-kbproto lib32-perl
lib32-cryptodev-headers lib32-libgcc lib32-python
lib32-db lib32-libmpc lib32-readline
lib32-eglibc lib32-libpthread-stubs lib32-sqlite3
lib32-eglibc-initial lib32-libtool-cross lib32-util-macros
lib32-expat lib32-libx11 lib32-valgrind
lib32-flex lib32-libxau lib32-xcb-proto
lib32-gcc lib32-libxcb lib32-xextproto
lib32-gcc-cross lib32-libxdmcp lib32-xproto
lib32-gcc-cross-initial lib32-linux-libc-headers lib32-xtrans
lib32-gcc-runtime lib32-m4 lib32-zlib
lib32-gdbm lib32-mpfr
5,713 次查看
Marklyu
thanks much for your answer!!!
5,712 次查看
yipingwang
Welcome
%3CLINGO-SUB%20id%3D%22lingo-sub-1946920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Edsp%E5%90%AF%E5%8A%A8%E6%BA%90%E4%BB%A3%E7%A0%81B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1946920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8QorIQ-SDK-1_7-IC-RevA%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E7%9C%8B%E5%88%B0%E7%AC%AC8%E7%AB%A0linux%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4IPC%EF%BC%8C%E5%85%B6%E4%B8%AD%E6%9C%89dsp_boot%EF%BC%88dsp%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%89%E9%83%A8%E5%88%86%E3%80%82%E6%83%B3%E7%9F%A5%E9%81%93%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%8F%96%2F%E4%B8%8B%E8%BD%BD%E5%AE%83%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%9Fdsp_boot%E6%BA%90%E4%BB%A3%E7%A0%81%E5%8C%85%E5%90%AB%E5%9C%A8sdk%E7%9A%84%E5%93%AA%E4%B8%AA%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EMark%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ADSP%E5%90%AF%E5%8A%A8%E6%BA%90%E4%BB%A3%E7%A0%81B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ADSP%E5%90%AF%E5%8A%A8%E6%BA%90%E4%BB%A3%E7%A0%81B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%E5%9C%A8%20ppc64e6500-fsl-linux%2Fipc-ust%2Fgit-r0%2Fgit%20%E6%89%BE%E5%88%B0%E4%BA%86%E6%BA%90%E4%BB%A3%E7%A0%81%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ADSP%E5%90%AF%E5%8A%A8%E6%BA%90%E4%BB%A3%E7%A0%81B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E8%BD%AC%E5%88%B0%E6%96%87%E4%BB%B6%E5%A4%B9%20build_b4860qds%2Ftmp%2Fwork%2F%20%E5%B9%B6%E8%BF%90%E8%A1%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AF%BB%E6%89%BE%20%E3%80%82-name%20ipc-ust%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ADSP%E5%90%AF%E5%8A%A8%E6%BA%90%E4%BB%A3%E7%A0%81B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E6%A3%80%E6%9F%A5%3CSPAN%3Ebuild_b4860qds%2Ftmp%2Fwork%2Fppce6500-fsl-linux%2Fipc-ust%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ADSP%E5%90%AF%E5%8A%A8%E6%BA%90%E4%BB%A3%E7%A0%81B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%BD%A0%E7%9A%84%E5%BB%BA%E8%AE%AE%E6%93%8D%E4%BD%9C%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A6%82%E4%B8%8B%E3%80%82%E9%82%A3%E4%B9%88%E5%B0%B1%E6%B2%A1%E6%9C%89%E6%BA%90%E4%BB%A3%E7%A0%81%E6%96%87%E4%BB%B6%E5%A4%B9%E3%80%82%3C%2FP%3E%3CP%3Ebuild_b4860qds-64b_release%5D%24%20bitbake%20ipc-ust%20-c%20patch%20-f%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E4%B8%BB%E6%9C%BA%E5%88%86%E5%B8%83%E2%80%9CCentOS-7.2.1511%E2%80%9D%E5%B0%9A%E6%9C%AA%E9%80%9A%E8%BF%87%E6%AD%A4%E7%89%88%E6%9C%AC%E7%9A%84%E6%9E%84%E5%BB%BA%E7%B3%BB%E7%BB%9F%E8%BF%9B%E8%A1%8C%E9%AA%8C%E8%AF%81%EF%BC%9B%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E9%81%87%E5%88%B0%E6%84%8F%E5%A4%96%E6%95%85%E9%9A%9C%E3%80%82%E5%BB%BA%E8%AE%AE%E6%82%A8%E4%BD%BF%E7%94%A8%E7%BB%8F%E8%BF%87%E6%B5%8B%E8%AF%95%E7%9A%84%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%82%3CBR%20%2F%3E%E5%8A%A0%E8%BD%BD%E7%BC%93%E5%AD%98%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20%E9%A2%84%E8%AE%A1%E5%88%B0%E8%BE%BE%E6%97%B6%E9%97%B4%EF%BC%9A00%3A00%3A00%3CBR%20%2F%3E%E4%BB%8E%E4%BE%9D%E8%B5%96%E7%BC%93%E5%AD%98%E4%B8%AD%E5%8A%A0%E8%BD%BD%E4%BA%86%203921%20%E4%B8%AA%E6%9D%A1%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%A7%A3%E5%86%B3%E4%BB%BB%E4%BD%95%E7%BC%BA%E5%A4%B1%E7%9A%84%E4%BB%BB%E5%8A%A1%E9%98%9F%E5%88%97%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%3C%2FP%3E%3CP%3E%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3E%20BB_VERSION%20%3D%20%221.22.0%22%3CBR%20%2F%3EBUILD_SYS%20%3D%E2%80%9Cx86_64-linux%E2%80%9D%3CBR%20%2F%3E%20NATIVELSBSTRING%20%3D%20%22CentOS-7.2.1511%22%3CBR%20%2F%3E%20TARGET_SYS%20%3D%E2%80%9Cpowerpc64-fsl-linux%E2%80%9D%3CBR%20%2F%3E%E6%9C%BA%E5%99%A8%20%3D%20%22b4860qds-64b%22%3CBR%20%2F%3E%E5%8F%91%E8%A1%8C%E7%89%88%20%3D%20%E2%80%9Cfsl-networking%E2%80%9D%3CBR%20%2F%3E%E5%8F%91%E8%A1%8C%E7%89%88%E6%9C%AC%20%3D%20%221.6%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%E2%80%9Cm64%20fpu-hard%20e6500%20altivec%E2%80%9D%3CBR%20%2F%3E%20TARGET_FPU%20%3D%E2%80%9C%E7%A1%AC%E2%80%9D%3CBR%20%2F%3E%E5%85%83%3CBR%20%2F%3Emeta-yocto%3CBR%20%2F%3E%20meta-yocto-bsp%20%3D%E2%80%9C%EF%BC%88%E4%BB%8Efsl-sdk-v1.6%E5%88%86%E7%A6%BB%EF%BC%89%EF%BC%9A0d2ce44c2b0f8cc9699e30cca2c24655be89d58b%E2%80%9D%3CBR%20%2F%3Emeta-fsl-ppc%20%3D%E2%80%9C%EF%BC%88%E4%BB%8Efsl-sdk-v1.6%E5%88%86%E7%A6%BB%EF%BC%89%EF%BC%9A6cf59d9de63a9fc5f8942c0d10c622898f4315ce%E2%80%9D%3CBR%20%2F%3Emeta-fsl-ppc-%E5%B7%A5%E5%85%B7%E9%93%BE%3D%E2%80%9C%EF%BC%88%E4%BB%8Efsl-sdk-v1.6%E5%88%86%E7%A6%BB%EF%BC%89%EF%BC%9Aa546e42f86e7d57de19e27907365d170b13fc18f%E2%80%9D%3CBR%20%2F%3E%E5%85%83%20fsl%20%E7%BD%91%E7%BB%9C%3CBR%20%2F%3Emeta%20fsl%E7%BD%91%E7%BB%9C%3D%E2%80%9C%EF%BC%88%E4%BB%8E8dec9c6%E5%88%86%E7%A6%BB%EF%BC%89%EF%BC%9A8dec9c690188cce5305ef5055f91e5cfa35c63f4%E2%80%9D%3CBR%20%2F%3E%E5%85%83%E8%99%9A%E6%8B%9F%E5%8C%96%3CBR%20%2F%3E%E5%85%83%E8%99%9A%E6%8B%9F%E5%8C%96%3D%E2%80%9C%EF%BC%88%E4%BB%8Efsl-sdk-v1.6%E5%88%86%E7%A6%BB%EF%BC%89%EF%BC%9A8044073f63a0d99541a43ac5f2f6d789f94c7c7c%E2%80%9D%3CBR%20%2F%3E%E5%85%83%3CBR%20%2F%3E%E5%85%83%E7%BD%91%E7%BB%9C%3CBR%20%2F%3E%E5%85%83%E7%BD%91%E7%BB%9C%E6%9C%8D%E5%8A%A1%E5%99%A8%3CBR%20%2F%3E%E5%85%83%E7%BA%A2%E5%AE%9D%E7%9F%B3%3CBR%20%2F%3E%E5%85%83%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3D%E2%80%9C%EF%BC%88%E4%BB%8Efsl-sdk-v1.6%E5%88%86%E7%A6%BB%EF%BC%89%EF%BC%9Ab86007f742a1b829ccc8d76e485bb3f789cefaa4%E2%80%9D%3CBR%20%2F%3Emeta-java%20%3D%E2%80%9C%EF%BC%88%E4%BB%8Efsl-sdk-v1.6%E5%88%86%E7%A6%BB%EF%BC%89%EF%BC%9Ad01f7d39e513790ddce20e6724723722119a3700%E2%80%9D%3CBR%20%2F%3E%E5%85%83OpenStack%3CBR%20%2F%3E%20meta-openstack-%E8%AE%A1%E7%AE%97-%E9%83%A8%E7%BD%B2%3CBR%20%2F%3Emeta-openstack-%E6%8E%A7%E5%88%B6%E5%99%A8%E9%83%A8%E7%BD%B2%3CBR%20%2F%3Emeta-openstack-qemu%20%3D%E2%80%9C%EF%BC%88%E4%BB%8Efsl-sdk-v1.6%E5%88%86%E7%A6%BB%EF%BC%89%EF%BC%9Af627404399a134672e0b5e26a0d9b794a6f8adf4%E2%80%9D%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E5%87%86%E5%A4%87%E8%BF%90%E8%A1%8C%E9%98%9F%E5%88%97%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%B1%A1%E6%9F%93%E5%93%88%E5%B8%8C%E4%BB%A5%E5%BC%BA%E5%88%B6%E9%87%8D%E5%BB%BA%E4%BB%BB%E5%8A%A1%2Fsdb%2Fmarklyu%2FQorIQ-SDK-V1.6-20140619-yocto%2Fmeta-fsl-ppc%2Frecipes-bsp%2Fipc%2Fipc-ust_git.bb%EF%BC%8C%E5%81%9A%E8%A1%A5%E4%B8%81%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%89%A7%E8%A1%8C%20SetScene%20%E4%BB%BB%E5%8A%A1%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%89%A7%E8%A1%8C%20RunQueue%20%E4%BB%BB%E5%8A%A1%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E4%BB%BB%E5%8A%A1%E6%91%98%E8%A6%81%EF%BC%9A%E5%B0%9D%E8%AF%95%E4%BA%86%2010%20%E9%A1%B9%E4%BB%BB%E5%8A%A1%EF%BC%8C%E5%85%B6%E4%B8%AD%209%20%E9%A1%B9%E4%B8%8D%E9%9C%80%E8%A6%81%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%85%A8%E9%83%A8%E6%88%90%E5%8A%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%91%98%E8%A6%81%EF%BC%9A%E6%98%BE%E7%A4%BA%E4%BA%86%201%20%E6%9D%A1%E8%AD%A6%E5%91%8A%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1952971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ADSP%E5%90%AF%E5%8A%A8%E6%BA%90%E4%BB%A3%E7%A0%81B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1952971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%AC%A2%E8%BF%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1952970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ADSP%E5%90%AF%E5%8A%A8%E6%BA%90%E4%BB%A3%E7%A0%81B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1952970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94%EF%BC%81%3C%2FLINGO-BODY%3E
