dsp boot source code B4860
Marklyu
i use the QorIQ-SDK-1_7-IC-RevA,
i see the chapter 8 linux user space  IPC, there is dsp_boot (source code of dsp boot loader)part. want to know where can i get/download the source code of it ? the dsp_boot source code is included in the sdk which folder ?
Mark
yipingwang
In your Yocto build environment, please run the following command.
$ bitbake ipc-ust -c patch -f
You will get dsp_boot source code in folder.
build_b4860qds/tmp/work/ppce6500-fsl-linux/ipc-ust/git-r0/git/dsp_boot/
yipingwang
Marklyu
i follow your advice , and the log as below. then there is no source code folder.
build_b4860qds-64b_release]$ bitbake ipc-ust -c patch -f
WARNING: Host distribution "CentOS-7.2.1511" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |######################################| ETA: 00:00:00
Loaded 3921 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.22.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "CentOS-7.2.1511"
TARGET_SYS = "powerpc64-fsl-linux"
MACHINE = "b4860qds-64b"
DISTRO = "fsl-networking"
DISTRO_VERSION = "1.6"
TUNE_FEATURES = "m64 fpu-hard e6500 altivec"
TARGET_FPU = "hard"
meta
meta-yocto
meta-yocto-bsp = "(detachedfromfsl-sdk-v1.6):0d2ce44c2b0f8cc9699e30cca2c24655be89d58b"
meta-fsl-ppc = "(detachedfromfsl-sdk-v1.6):6cf59d9de63a9fc5f8942c0d10c622898f4315ce"
meta-fsl-ppc-toolchain = "(detachedfromfsl-sdk-v1.6):a546e42f86e7d57de19e27907365d170b13fc18f"
meta-fsl-networking
meta-fsl-networking = "(detachedfrom8dec9c6):8dec9c690188cce5305ef5055f91e5cfa35c63f4"
meta-virtualization
meta-virtualization = "(detachedfromfsl-sdk-v1.6):8044073f63a0d99541a43ac5f2f6d789f94c7c7c"
meta-oe
meta-networking
meta-webserver
meta-ruby
meta-filesystems = "(detachedfromfsl-sdk-v1.6):b86007f742a1b829ccc8d76e485bb3f789cefaa4"
meta-java = "(detachedfromfsl-sdk-v1.6):d01f7d39e513790ddce20e6724723722119a3700"
meta-openstack
meta-openstack-compute-deploy
meta-openstack-controller-deploy
meta-openstack-qemu = "(detachedfromfsl-sdk-v1.6):f627404399a134672e0b5e26a0d9b794a6f8adf4"
NOTE: Preparing runqueue
NOTE: Tainting hash to force rebuild of task /sdb/marklyu/QorIQ-SDK-V1.6-20140619-yocto/meta-fsl-ppc/recipes-bsp/ipc/ipc-ust_git.bb, do_patch
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: Tasks Summary: Attempted 10 tasks of which 9 didn't need to be rerun and all succeeded.
Summary: There was 1 WARNING message shown.
yipingwang
Please check whether build_b4860qds/tmp/work/ppce6500-fsl-linux/ipc-ust exists.
yipingwang
Please go to folder build_b4860qds/tmp/work/ and run the following command.
find . -name ipc-ust
Marklyu
thanks much . found the source code files at ppc64e6500-fsl-linux/ipc-ust/git-r0/git.
yipingwang
OK, thanks.
Marklyu
no, there is no ipc-ust folder under the  ppce6500-fsl-linux.
ppce6500-fsl-linux]$ ls
lib32-binutils lib32-gettext lib32-ncurses
lib32-binutils-cross lib32-gmp lib32-openssl
lib32-bison lib32-inputproto lib32-opkg-utils
lib32-bzip2 lib32-kbproto lib32-perl
lib32-cryptodev-headers lib32-libgcc lib32-python
lib32-db lib32-libmpc lib32-readline
lib32-eglibc lib32-libpthread-stubs lib32-sqlite3
lib32-eglibc-initial lib32-libtool-cross lib32-util-macros
lib32-expat lib32-libx11 lib32-valgrind
lib32-flex lib32-libxau lib32-xcb-proto
lib32-gcc lib32-libxcb lib32-xextproto
lib32-gcc-cross lib32-libxdmcp lib32-xproto
lib32-gcc-cross-initial lib32-linux-libc-headers lib32-xtrans
lib32-gcc-runtime lib32-m4 lib32-zlib
lib32-gdbm lib32-mpfr
Marklyu
thanks much for your answer!!!
yipingwang
Welcome
%3CLINGO-SUB%20id%3D%22lingo-sub-1946920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Edsp%20boot%20source%20code%20B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1946920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ei%20use%20the%20QorIQ-SDK-1_7-IC-RevA%2C%26nbsp%3B%3C%2FP%3E%3CP%3Ei%20see%20the%20chapter%208%20linux%20user%20space%26nbsp%3B%20IPC%2C%20there%20is%20dsp_boot%20(source%20code%20of%20dsp%20boot%20loader)part.%20want%20to%20know%20where%20can%20i%20get%2Fdownload%20the%20source%20code%20of%20it%20%3F%20the%20dsp_boot%20source%20code%20is%20included%20in%20the%20sdk%20which%20folder%20%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EMark%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp%20boot%20source%20code%20B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOK%2C%20thanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp%20boot%20source%20code%20B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ethanks%20much%20.%20found%20the%20source%20code%20files%20at%26nbsp%3Bppc64e6500-fsl-linux%2Fipc-ust%2Fgit-r0%2Fgit.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp%20boot%20source%20code%20B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20go%20to%20folder%26nbsp%3Bbuild_b4860qds%2Ftmp%2Fwork%2F%20and%20run%20the%20following%20command.%3C%2FP%3E%0A%3CP%3Efind%20.%20-name%20ipc-ust%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp%20boot%20source%20code%20B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eno%2C%20there%20is%20no%26nbsp%3B%3CSPAN%3Eipc-ust%26nbsp%3Bfolder%20under%20the%26nbsp%3B%26nbsp%3Bppce6500-fsl-linux.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Eppce6500-fsl-linux%5D%24%20ls%3CBR%20%2F%3Elib32-binutils%20lib32-gettext%20lib32-ncurses%3CBR%20%2F%3Elib32-binutils-cross%20lib32-gmp%20lib32-openssl%3CBR%20%2F%3Elib32-bison%20lib32-inputproto%20lib32-opkg-utils%3CBR%20%2F%3Elib32-bzip2%20lib32-kbproto%20lib32-perl%3CBR%20%2F%3Elib32-cryptodev-headers%20lib32-libgcc%20lib32-python%3CBR%20%2F%3Elib32-db%20lib32-libmpc%20lib32-readline%3CBR%20%2F%3Elib32-eglibc%20lib32-libpthread-stubs%20lib32-sqlite3%3CBR%20%2F%3Elib32-eglibc-initial%20lib32-libtool-cross%20lib32-util-macros%3CBR%20%2F%3Elib32-expat%20lib32-libx11%20lib32-valgrind%3CBR%20%2F%3Elib32-flex%20lib32-libxau%20lib32-xcb-proto%3CBR%20%2F%3Elib32-gcc%20lib32-libxcb%20lib32-xextproto%3CBR%20%2F%3Elib32-gcc-cross%20lib32-libxdmcp%20lib32-xproto%3CBR%20%2F%3Elib32-gcc-cross-initial%20lib32-linux-libc-headers%20lib32-xtrans%3CBR%20%2F%3Elib32-gcc-runtime%20lib32-m4%20lib32-zlib%3CBR%20%2F%3Elib32-gdbm%20lib32-mpfr%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp%20boot%20source%20code%20B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20check%20whether%26nbsp%3B%3CSPAN%3Ebuild_b4860qds%2Ftmp%2Fwork%2Fppce6500-fsl-linux%2Fipc-ust%20exists.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp%20boot%20source%20code%20B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ei%20follow%20your%20advice%20%2C%20and%20the%20log%20as%20below.%20then%20there%20is%20no%20source%20code%20folder.%3C%2FP%3E%3CP%3Ebuild_b4860qds-64b_release%5D%24%20bitbake%20ipc-ust%20-c%20patch%20-f%3CBR%20%2F%3EWARNING%3A%20Host%20distribution%20%22CentOS-7.2.1511%22%20has%20not%20been%20validated%20with%20this%20version%20of%20the%20build%20system%3B%20you%20may%20possibly%20experience%20unexpected%20failures.%20It%20is%20recommended%20that%20you%20use%20a%20tested%20distribution.%3CBR%20%2F%3ELoading%20cache%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20ETA%3A%2000%3A00%3A00%3CBR%20%2F%3ELoaded%203921%20entries%20from%20dependency%20cache.%3CBR%20%2F%3ENOTE%3A%20Resolving%20any%20missing%20task%20queue%20dependencies%3C%2FP%3E%3CP%3EBuild%20Configuration%3A%3CBR%20%2F%3EBB_VERSION%20%3D%20%221.22.0%22%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3ENATIVELSBSTRING%20%3D%20%22CentOS-7.2.1511%22%3CBR%20%2F%3ETARGET_SYS%20%3D%20%22powerpc64-fsl-linux%22%3CBR%20%2F%3EMACHINE%20%3D%20%22b4860qds-64b%22%3CBR%20%2F%3EDISTRO%20%3D%20%22fsl-networking%22%3CBR%20%2F%3EDISTRO_VERSION%20%3D%20%221.6%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22m64%20fpu-hard%20e6500%20altivec%22%3CBR%20%2F%3ETARGET_FPU%20%3D%20%22hard%22%3CBR%20%2F%3Emeta%3CBR%20%2F%3Emeta-yocto%3CBR%20%2F%3Emeta-yocto-bsp%20%3D%20%22(detachedfromfsl-sdk-v1.6)%3A0d2ce44c2b0f8cc9699e30cca2c24655be89d58b%22%3CBR%20%2F%3Emeta-fsl-ppc%20%3D%20%22(detachedfromfsl-sdk-v1.6)%3A6cf59d9de63a9fc5f8942c0d10c622898f4315ce%22%3CBR%20%2F%3Emeta-fsl-ppc-toolchain%20%3D%20%22(detachedfromfsl-sdk-v1.6)%3Aa546e42f86e7d57de19e27907365d170b13fc18f%22%3CBR%20%2F%3Emeta-fsl-networking%3CBR%20%2F%3Emeta-fsl-networking%20%3D%20%22(detachedfrom8dec9c6)%3A8dec9c690188cce5305ef5055f91e5cfa35c63f4%22%3CBR%20%2F%3Emeta-virtualization%3CBR%20%2F%3Emeta-virtualization%20%3D%20%22(detachedfromfsl-sdk-v1.6)%3A8044073f63a0d99541a43ac5f2f6d789f94c7c7c%22%3CBR%20%2F%3Emeta-oe%3CBR%20%2F%3Emeta-networking%3CBR%20%2F%3Emeta-webserver%3CBR%20%2F%3Emeta-ruby%3CBR%20%2F%3Emeta-filesystems%20%3D%20%22(detachedfromfsl-sdk-v1.6)%3Ab86007f742a1b829ccc8d76e485bb3f789cefaa4%22%3CBR%20%2F%3Emeta-java%20%3D%20%22(detachedfromfsl-sdk-v1.6)%3Ad01f7d39e513790ddce20e6724723722119a3700%22%3CBR%20%2F%3Emeta-openstack%3CBR%20%2F%3Emeta-openstack-compute-deploy%3CBR%20%2F%3Emeta-openstack-controller-deploy%3CBR%20%2F%3Emeta-openstack-qemu%20%3D%20%22(detachedfromfsl-sdk-v1.6)%3Af627404399a134672e0b5e26a0d9b794a6f8adf4%22%3C%2FP%3E%3CP%3ENOTE%3A%20Preparing%20runqueue%3CBR%20%2F%3ENOTE%3A%20Tainting%20hash%20to%20force%20rebuild%20of%20task%20%2Fsdb%2Fmarklyu%2FQorIQ-SDK-V1.6-20140619-yocto%2Fmeta-fsl-ppc%2Frecipes-bsp%2Fipc%2Fipc-ust_git.bb%2C%20do_patch%3CBR%20%2F%3ENOTE%3A%20Executing%20SetScene%20Tasks%3CBR%20%2F%3ENOTE%3A%20Executing%20RunQueue%20Tasks%3CBR%20%2F%3ENOTE%3A%20Tasks%20Summary%3A%20Attempted%2010%20tasks%20of%20which%209%20didn't%20need%20to%20be%20rerun%20and%20all%20succeeded.%3C%2FP%3E%3CP%3ESummary%3A%20There%20was%201%20WARNING%20message%20shown.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1952971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp%20boot%20source%20code%20B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1952971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWelcome%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1952970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp%20boot%20source%20code%20B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1952970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ethanks%20much%20for%20your%20answer!!!%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1952965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp%20boot%20source%20code%20B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1952965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIn%20your%20Yocto%20build%20environment%2C%20please%20run%20the%20following%20command.%3C%2FP%3E%0A%3CP%3E%24%20bitbake%20ipc-ust%20-c%20patch%20-f%3C%2FP%3E%0A%3CP%3EYou%20will%20get%26nbsp%3Bdsp_boot%20source%20code%20in%20folder.%3C%2FP%3E%0A%3CP%3Ebuild_b4860qds%2Ftmp%2Fwork%2Fppce6500-fsl-linux%2Fipc-ust%2Fgit-r0%2Fgit%2Fdsp_boot%2F%3C%2FP%3E%3C%2FLINGO-BODY%3E
