dsp boot source code B4860
5,511件の閲覧回数
Marklyu
i use the QorIQ-SDK-1_7-IC-RevA,
i see the chapter 8 linux user space  IPC, there is dsp_boot (source code of dsp boot loader)part. want to know where can i get/download the source code of it ? the dsp_boot source code is included in the sdk which folder ?
Mark
5,479件の閲覧回数
yipingwang
In your Yocto build environment, please run the following command.
$ bitbake ipc-ust -c patch -f
You will get dsp_boot source code in folder.
build_b4860qds/tmp/work/ppce6500-fsl-linux/ipc-ust/git-r0/git/dsp_boot/
9 返答(返信)
5,480件の閲覧回数
yipingwang
5,426件の閲覧回数
Marklyu
i follow your advice , and the log as below. then there is no source code folder.
build_b4860qds-64b_release]$ bitbake ipc-ust -c patch -f
WARNING: Host distribution "CentOS-7.2.1511" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |######################################| ETA: 00:00:00
Loaded 3921 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.22.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "CentOS-7.2.1511"
TARGET_SYS = "powerpc64-fsl-linux"
MACHINE = "b4860qds-64b"
DISTRO = "fsl-networking"
DISTRO_VERSION = "1.6"
TUNE_FEATURES = "m64 fpu-hard e6500 altivec"
TARGET_FPU = "hard"
meta
meta-yocto
meta-yocto-bsp = "(detachedfromfsl-sdk-v1.6):0d2ce44c2b0f8cc9699e30cca2c24655be89d58b"
meta-fsl-ppc = "(detachedfromfsl-sdk-v1.6):6cf59d9de63a9fc5f8942c0d10c622898f4315ce"
meta-fsl-ppc-toolchain = "(detachedfromfsl-sdk-v1.6):a546e42f86e7d57de19e27907365d170b13fc18f"
meta-fsl-networking
meta-fsl-networking = "(detachedfrom8dec9c6):8dec9c690188cce5305ef5055f91e5cfa35c63f4"
meta-virtualization
meta-virtualization = "(detachedfromfsl-sdk-v1.6):8044073f63a0d99541a43ac5f2f6d789f94c7c7c"
meta-oe
meta-networking
meta-webserver
meta-ruby
meta-filesystems = "(detachedfromfsl-sdk-v1.6):b86007f742a1b829ccc8d76e485bb3f789cefaa4"
meta-java = "(detachedfromfsl-sdk-v1.6):d01f7d39e513790ddce20e6724723722119a3700"
meta-openstack
meta-openstack-compute-deploy
meta-openstack-controller-deploy
meta-openstack-qemu = "(detachedfromfsl-sdk-v1.6):f627404399a134672e0b5e26a0d9b794a6f8adf4"
NOTE: Preparing runqueue
NOTE: Tainting hash to force rebuild of task /sdb/marklyu/QorIQ-SDK-V1.6-20140619-yocto/meta-fsl-ppc/recipes-bsp/ipc/ipc-ust_git.bb, do_patch
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: Tasks Summary: Attempted 10 tasks of which 9 didn't need to be rerun and all succeeded.
Summary: There was 1 WARNING message shown.
5,423件の閲覧回数
yipingwang
Please check whether build_b4860qds/tmp/work/ppce6500-fsl-linux/ipc-ust exists.
5,418件の閲覧回数
yipingwang
Please go to folder build_b4860qds/tmp/work/ and run the following command.
find . -name ipc-ust
5,398件の閲覧回数
Marklyu
thanks much . found the source code files at ppc64e6500-fsl-linux/ipc-ust/git-r0/git.
5,396件の閲覧回数
yipingwang
OK, thanks.
5,420件の閲覧回数
Marklyu
no, there is no ipc-ust folder under the  ppce6500-fsl-linux.
ppce6500-fsl-linux]$ ls
lib32-binutils lib32-gettext lib32-ncurses
lib32-binutils-cross lib32-gmp lib32-openssl
lib32-bison lib32-inputproto lib32-opkg-utils
lib32-bzip2 lib32-kbproto lib32-perl
lib32-cryptodev-headers lib32-libgcc lib32-python
lib32-db lib32-libmpc lib32-readline
lib32-eglibc lib32-libpthread-stubs lib32-sqlite3
lib32-eglibc-initial lib32-libtool-cross lib32-util-macros
lib32-expat lib32-libx11 lib32-valgrind
lib32-flex lib32-libxau lib32-xcb-proto
lib32-gcc lib32-libxcb lib32-xextproto
lib32-gcc-cross lib32-libxdmcp lib32-xproto
lib32-gcc-cross-initial lib32-linux-libc-headers lib32-xtrans
lib32-gcc-runtime lib32-m4 lib32-zlib
lib32-gdbm lib32-mpfr
5,475件の閲覧回数
Marklyu
thanks much for your answer!!!
5,474件の閲覧回数
yipingwang
Welcome
%3CLINGO-SUB%20id%3D%22lingo-sub-1946920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDSP%E3%83%96%E3%83%BC%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1946920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFQorIQ-SDK-1_7-IC-RevA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%AC%AC8%E7%AB%A0%E3%81%AELinux%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9IPC%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81dsp_boot(dsp%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89)%E3%81%AE%E9%83%A8%E5%88%86%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E5%85%A5%E6%89%8B%2F%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3Fdsp_boot%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AFSDK%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMark%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Adsp%E3%83%96%E3%83%BC%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Adsp%E3%83%96%E3%83%BC%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AFppc64e6500-fsl-linux%2Fipc-ust%2Fgit-r0%2Fgit%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Adsp%E3%83%96%E3%83%BC%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80build_b4860qds%2Ftmp%2Fwork%2F%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%A6%8B%E4%BB%98%E3%81%91%E3%82%8B%E3%80%82-%E5%90%8D%E5%89%8D%20IPC-UST%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Adsp%E3%83%96%E3%83%BC%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Ebuild_b4860qds%2Ftmp%2Fwork%2Fppce6500-fsl-linux%2Fipc-ust%20%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%3C%2FSPAN%3E%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Adsp%E3%83%96%E3%83%BC%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E5%BE%93%E3%81%84%E3%80%81%E3%83%AD%E3%82%B0%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Ebuild_b4860qds-64b_release%5D%24%20bitbake%20ipc-ust%20-c%20patch%20-f%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E3%83%9B%E3%82%B9%E3%83%88%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%22CentOS-7.2.1511%22%20%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%AF%E6%A4%9C%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BA%88%E6%9C%9F%E3%81%97%E3%81%AA%E3%81%84%E9%9A%9C%E5%AE%B3%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%86%E3%82%B9%E3%83%88%E6%B8%88%E3%81%BF%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%E5%88%B0%E7%9D%80%E4%BA%88%E5%AE%9A%E6%99%82%E5%88%BB%3A%2000%3A00%3A00%3CBR%20%2F%3E%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%203921%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%3A%20%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AE%E8%A7%A3%E6%B1%BA%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%3A%3CBR%20%2F%3EBB_VERSION%20%3D%20%221.22.0%22%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3ENATIVELSBSTRING%20%3D%20%22CentOS-7.2.1511%22%3CBR%20%2F%3ETARGET_SYS%20%3D%20%22powerpc64-fsl-linux%22%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%20%3D%20%22b4860qds-64b%22%3CBR%20%2F%3EDISTRO%20%3D%20%22fsl-networking%22%3CBR%20%2F%3EDISTRO_VERSION%20%3D%20%221.6%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22M64%20FPU-Hard%20E6500%20Altivec%22%3CBR%20%2F%3ETARGET_FPU%20%3D%20%E3%80%8C%E7%A1%AC%E3%81%84%E3%80%8D%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%83%A8%E3%82%AF%E3%83%88%3CBR%20%2F%3Emeta-yocto-bsp%20%3D%20%22(detachedfromfsl-sdk-v1.6)%3A0d2ce44c2b0f8cc9699e30cca2c24655be89d58b%22%3CBR%20%2F%3Emeta-fsl-ppc%20%3D%20%22(detachedfromfsl-sdk-v1.6)%3A6cf59d9de63a9fc5f8942c0d10c622898f4315ce%22%3CBR%20%2F%3Emeta-fsl-ppc-toolchain%20%3D%20%22(detachedfromfsl-sdk-v1.6)%3Aa546e42f86e7d57de19e27907365d170b13fc18f%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF-FSL%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%3CBR%20%2F%3Emeta-fsl-networking%20%3D%20%22(detachedfrom8dec9c6)%3A8dec9c690188cce5305ef5055f91e5cfa35c63f4%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E4%BB%AE%E6%83%B3%E5%8C%96%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E4%BB%AE%E6%83%B3%E5%8C%96%3D%20%22(detachedfromfsl-sdk-v1.6)%3A8044073f63a0d99541a43ac5f2f6d789f94c7c7c%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BFOE%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%20Web%20%E3%82%B5%E3%83%BC%E3%83%90%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%83%AB%E3%83%93%E3%83%BC%3CBR%20%2F%3Emeta-filesystems%20%3D%20%22(detachedfromfsl-sdk-v1.6)%3Ab86007f742a1b829ccc8d76e485bb3f789cefaa4%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%82%B8%E3%83%A3%E3%83%90%3D%20%22(detachedfromfsl-sdk-v1.6)%3Ad%2001f7d39e513790ddce20e6724723722119a3700%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%20openstack-compute-deploy%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%20OpenStack%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3CBR%20%2F%3Emeta-openstack-qemu%20%3D%20%22(detachedfromfsl-sdk-v1.6)%3Af627404399a134672e0b5e26a0d9b794a6f8adf4%22%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%3A%20%E3%83%A9%E3%83%B3%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E6%BA%96%E5%82%99%3CBR%20%2F%3E%E6%B3%A8%3A%E3%82%BF%E3%82%B9%E3%82%AF%2Fsdb%2Fmarklyu%2FQorIQ-SDK-V1.6-20140619-yocto%2Fmeta-fsl-ppc%2Frecipes-bsp%2Fipc%2Fipc-ust_git.bb%E3%80%81do_patch%3CBR%20%2F%3E%E6%B3%A8%3A%20SetScene%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E6%B3%A8%3A%20RunQueue%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E6%B3%A8%3A%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A10%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A19%E5%80%8B%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%3A%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C1%E3%81%A4%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1952971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Adsp%E3%83%96%E3%83%BC%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1952971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%88%E3%81%86%E3%81%93%E3%81%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1952970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Adsp%E3%83%96%E3%83%BC%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89B4860%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1952970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!!%3C%2FLINGO-BODY%3E
