UART Connections!
已解决
UART Connections!
跳至解决方案
3,980 次查看
qammarabbas
I found a reference schematics of T1042. While connecting UART's pins to the DB9 connector (through driver IC), it uses a series RLC circuit. Can somebody explain its reason?
Please find the attached image for your information. Thank you!
标记 (1)
1 解答
3,882 次查看
r8070z
The series RLC circuit is a low-pass filter. It cuts radio-frequency noise and decreases electromagnetic interference (EMI).
在原帖中查看解决方案
2 回复数
3,883 次查看
r8070z
3,882 次查看
qammarabbas
Thank you!
